where is the purge valve in located?
Old Nov 18, 2010 | 08:18 PM
Simprof's Avatar
Default where is the purge valve in located?
So, know one has any idea where the fuel tank purge vave is located on an 1997 XJR-6. Okay that seems quite strange. I have asked this before and get know answers. Please I need to know where to start looking..
Old Nov 18, 2010 | 11:11 PM
Doug's Avatar
The closest I can find in the manuals is a "evaporative emissions control valve" which is "below LH front relays"...I think that means the bank of relays in front of the air filter housing. It has purple/green and black/light green wires. I reckon it'll have a hose or two as well.
Old Nov 19, 2010 | 08:38 AM
Simprof's Avatar
Thumbs up
Thanks Doug I will start at that point. I was not trying to be a pain the way I wrote my inquiries it was just I could not get an answer from antone for some reason I was unable to find it in the car. The canister is under the rear left fender but that's as far as I could go, I lost the line after that.. So once again thank you for your input..
Old Nov 22, 2010 | 10:38 AM
Drew's Avatar
I hope this helps.
Attached Thumbnails where is the purge valve in located?-purge-control-valve2.jpg
Old Nov 23, 2010 | 07:44 AM
Simprof's Avatar
Thumbs up
You bet and what can I say but thanks for the picture, as they say one picture is worth a thousand words.. Where ever did you find it?
Thanks again
Old Nov 23, 2010 | 08:38 AM
Drew's Avatar
Jtis
bamforp
Aug 14, 2024 05:36 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
TheWarlock
Jun 25, 2020 05:24 PM
amaezing
Sep 18, 2015 03:25 PM
explorer364
Sep 11, 2015 05:44 PM
