Where is the SLCM? (X300 remote fob programming issues, USA)
Old Dec 13, 2011 | 03:09 AM
  #41
biffta's Avatar
Originally Posted by 96x300
is it at all possible to unplug this unit and install a 2 way/pager alarm such a Compustar or Viper?
Some time back when I was going through the trauma of trying to sort out this problem and the confusion about frequencies etc, I thought seriously about abandoning the Jaguar system altogether and installing another system to replace it.
Firstly, I don't think it's as easy as just unplugging one unit and plugging in another of a different make!
Wiring systems in cars are very complicated things and vary, not only between makes and models but also between different years and models of the same car!
Replacing the system would firstly need the correct wiring diagram for the car in question (as I said before the same basic model can have different wiring diagrams). Next, someone with auto electrician expertise willing and able to tackle this job.
All fine if you are capable of doing all this yourself, then I say good luck and report your experiences. But if you've got to pay someone to do this, coupled with buying the new system then surely it can't be more economical than fixing the existing Jaguar one?
Or can it?
Old Nov 20, 2013 | 07:56 PM
  #42
Pooljac's Avatar
*HELP* how can I tell which key fob I need, is it the 315mhz or the 433mhz 1996 VP XJ6
Old Nov 21, 2013 | 10:51 AM
  #43
xjrguy's Avatar
Look at the top center of your rear windscreen. Look where the two short security antennas come out of the square patch.
If one goes out the right side and one out the bottom, you have a 315 MHz system.
If they both go out the bottom of the patch and split, you have a 433 MHz system.
315 MHz = DBC11510 remote
433 MHz = DBC11512 remote
Cheers,
99xk8guy
May 28, 2024 09:36 PM
mbergen
Oct 23, 2019 10:26 PM
Rick Michael
Sep 6, 2015 06:53 PM
AL NZ
Sep 4, 2015 08:39 PM
My Pham
Sep 4, 2015 03:37 PM
