Will XJ8 lights fit a X300?
Hey thanks for the response. What do u mean by saying changing the whole setup and not just the lenses. I dont wanna go crazy with changing wiring and spending alot of money. Cant u just plug in the same bulbs into the lenses?? Thanks.
Yes, and i swapped mine out, they take differant bulb and connectors. Bulbs and connectors are avail on partsgeek.com for $5-6each and just butt connect them. I would also have the lenses covered in clear bra cause theyre glass too and not cheap to replace when you get a rock in them
I take it youre talking fronts here, I'll be doing rear upgrade at the week-end Ill drop pics on early next week, it may help someone
Hmmm yeah i guess someone should be specific front or rear lights so we all dont start assuming differant things
Fronts of course
so what if I just replace the lenses and not the wiring, cant I just slip the bulb into the socket and turning them just like on the the x300 lense. I have a hid system in the car right now....
No youll never get the glass apart. Theyre not plastic and heatable to soften the urethane. The glass ones are sealed differantly and ive tried to take apart a broken couple of glass lenses when it converted mine over to take hid projectors out of an stype so i have focused light, not scattered
Arghhhhhhh ....
One of the issues is going to be completely different aiming provisions, not to mention retention methods. But come to think of it, if the studs could be mounted on the back of the reflectors ... the aiming problem goes away.
It would be nice to go back to Cibies though.
It would essentially be cost free if the good stock units can be sold.
RoyLittle0
May 25, 2023 02:38 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
