wiper fluid warning light
Old Oct 2, 2012 | 06:24 PM
11Arrow's Avatar
Default wiper fluid warning light
Greetings, The windshield wiper warning light came on today.I refilled with fluid, but the light stays on.Is there a trick to resetting it. Thanks Kelly
Old Oct 5, 2012 | 12:57 PM
Vitamin C's Avatar
I had this problem when I first got my XJ6. The floater switch for the wiper fluid sensor can easily become jammed open once the wiper fluid gets low. Although I solved this problem by installing a new wiper fluid level sensor (I'd ordered it before draining and examining the reservoir), I believe that you may be able to fix it by simply pulling the sensor from the reservoir and unjamming the float switch.
To avoid this problem in the future, I have been keeping a close watch on my wiper fluid level so that it doesn't get low enough to trigger the switch.
Old Oct 5, 2012 | 09:53 PM
11Arrow's Avatar
Thanks for the info. I'll try that tomorrow.
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Jpav27
Jul 31, 2022 06:43 AM
edtexas
Sep 4, 2015 08:20 PM
