Wipers stopped working
Old Nov 7, 2009 | 06:53 PM
italcarnut's Avatar
Smile windshield wiper
I have had this problem also. It happened to me after a dumb greasemonkey turned the wipers on with the wiper frozen to the windshield. There is an arm that is pressed to a cylinder via a 8mm nut. The cylinder and arm have grooves that make everything work. The grooves are stripped. You must remove the whole assembly and disassemble everything until you get to these grooves. I put new grooves on the male side with a Dremel. The female side I did with a very small file. They don't have to be exact but they will work. The biggest pain is the removal and installation. Let me know if you need further help.
Regards,
Ruben Velez
Old Nov 15, 2009 | 04:19 PM
bhmaxjag's Avatar
Just tighten the nut, it came loose. It will operate even with stripped grooves if the nut is tightened properly. Make it nice and snug but not TOO tight. I like to use a battery powered 3/8 impact driver...quick zap and it's done
PMKimpton
Aug 3, 2019 08:22 PM
tberg
Sep 7, 2015 07:32 AM
philwarner
Sep 5, 2015 10:05 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
XJsc-guy
Sep 2, 2015 11:43 AM
