x300 4.0 transmission problem. Need help.
Old Jul 27, 2012 | 02:06 AM
martuwkin's Avatar
Exclamation x300 4.0 transmission problem. Need help.
Hi all! In my jaguar is the problem with automatic transmission. My model X300 xj6 4.0 Long, VIN-SAJHX1748SC731551.
The problem is that after I run the engine, includ DRIVE mode and go to places - for 2300-2900 tachometer is a jerk and kick and displayed emergency light Transmission in the upper left corner of the dashboard.
car rides, but slowly dispersed and when to stay and try to move from the place slow start. If the engine off and start again - the light transmission errors are not displayed. And it all starts again, the engine speed 2300-2800 transmission and emergency treatment ....
Errors engine no. Transmission dismantled and dismantled for inspection - inside all was well. But for warranty, I perfectly washed and replaced all seals and gaskets new set of disks. Substituted oil and oil filter. The problem persists. Check all wire connection and sensors. Everything is OK.
Question to all who can help by some device can read the error transmission my car?
I understand that correctly find the problem you need to know the error code. I tried different scanners but they see only the engine.
Can this help me -http://www.ebay.com/itm/370475284092?_trksid=p3984.m1423.l2649&item=370475 284092&viewitem=&sspagename=STRK:MEWAX:IT&vxp=mtr
Maybe someone had this problem? Help please ...
Old Jul 27, 2012 | 04:55 AM
Takeo's Avatar
Zdravstvuytye,
in case of a ZF 5HP24 tranny, you MUST also change the "F" piston during overhaul.
I case of another tranny, this sounds as partly clogged oil ducts, poor valve settings and that sort of thing.
T.
Old Oct 7, 2012 | 12:44 PM
Kevin Burnaby's Avatar
Default Transmission light
Originally Posted by martuwkin
Hi all! In my jaguar is the problem with automatic transmission/
I had a similar problem when I first got my car, it was northing to do with the transmission, it was the idle control valve. I had it cleaned and tested, that was 5 years ago and I have had no issues since with the transmission light and erratic fast idle. It is now 80,000 KM later.
Did your car sit without use for a long time?
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
Forcedair1
Feb 19, 2020 01:51 PM
SouthernGypsy
Sep 23, 2015 04:06 AM
b1mcp
Sep 13, 2015 07:31 PM
