X300 AC compressor
Old Aug 4, 2024 | 07:26 AM
tobywood13's Avatar
Default X300 AC compressor
Hi all, I went to get my AC regassed as it’s never worked since I’ve had my car. The technician said that it wouldn’t work as my compressor was leaking. I was expecting a mechanical failure rather than just no gas left to explain the not working AC, so this is not a surprise.
Is there any way to narrow down which part is leaking without all the proper AC kit? New compressors are quite expensive, so if it’s just a valve or something that would be nicer to replace.
If it does have to be the entire compressor, is it just a straight swap (unbolt one, put the new one in), or are there more things to be done at the same time? Thanks!
Old Aug 4, 2024 | 09:10 AM
Parker 7's Avatar
There is a climate control panel bite test to cover the bases shown as someone's video
There are detailed instructions in a following manual , see page 110 and there is a TSB to see the codes definition , this manual as the XJ section covers the same later X308 system
14-10 (jagrepair.com)
T703 BOOK (jagrepair.com)
There is a cheap reseal kit shown in this venders videos
You have a Denson 10PA series dash 17 ( ? ) compressor
Their cheap parts page doesn't seem to open but this is the main page
Automobile Air Conditioning Parts of Tucson Arizona, Century Auto Air, AC Parts, AC Service and Hoses, www.centuryautoair.com
See video part 1 and 2
More things to be done at the same time as compressor removal is the dryer replacement ( age lets the dryer beads loose clogging the TXP valve ) ) air blow out the TXP valve in reverse flow direction
Cabin temp sensor cleaning as this clogs with lint effecting overall cooling performance but does not show a code
Old Aug 4, 2024 | 10:48 AM
Parker 7's Avatar
In watching the Denso seal replacement video the top square seal can be preplaced without removing the compressor in theory
Then you can recharge the freon and go from there and drive away
This is a costs trading exercise if that one seal does the job or have to go deeper and get another freon recharge ( cost ) after a more complete seals replacement by removing compressor
Same thing as earlier recommended should be done on dryer full part replacement ( can't be repaired but at least it's a cheap part ) and cabin temp sensor cleaning ( use no solvent but clean with brush and air only )
Old Aug 4, 2024 | 11:55 AM
tobywood13's Avatar
Interesting, I’ll look into that seal.
Is there a dye I can inject to perform my own leak test? I say this because the compressor never kicks on presumably because the oil/refrigerant is too low, so I’m having trouble tracking down where exactly it was leaking from.
Old Aug 4, 2024 | 02:23 PM
Parker 7's Avatar
The words " compressor leak " is easier to say then taking the steps to know exactly what to say accurately , they move on to next customer and no more effort spent on you
They make a lot of parts markup profit and billable labor in replacement by selling you a new compressor
The leak test dye is avail , but you have to have the compressor rotating and a full or somewhat full freon charge to observe an external leak
The compressor clutch will not engage if the very low freon pressure switch ( a 4 wire ) protects the compressor, the clutch is always spinning externally so you can't get a visual confirmation
There is a fuse # 8 / 10 amp right engine bay fuse box for the compressor clutch and large relay # 3 right that should click by finger on it with A C on / off command
See page 21 and 17
X300 1996 LWB.pdf (jagrepair.com)
The know the compressor clutch is engaging and have someone turn the A / C on and listen for a clutch engagement , there should be a designed in time delay between A / C on and off
By yourself from the cabin is marginal if you can hear it from the cabin or notice engine RPMs / load change
The engine regulation is already shifted to higher RPMs to make up for assumed compressor load , it is a matter if both things are happening at the same time , regulation change being masked by the compressor load on engine
With a somewhat operating freon charge you can feel the different temps on the hot high pressure freon line ( this will be the line with the factory pressure switches on it } and the cold line to know if the clutch is engaging
The leak can be coming from a 2 wire freon pressure switch leaking that is subject of a TSB so they have a historical flag for leaking itself ( in paper ) , this 1 of 2 ( the other 4 wire ) freon pressure switches was removed in the TSB . In reality the 2 wire pressure switch can remain in place if not leaking ( the 4 wire is never touched ) and the connector pins are Jumper'd to accomplish the need / end effect of the TSB
Old Aug 4, 2024 | 09:12 PM
watto700's Avatar
G'day Toby,
I had a problem with my car aircon compressor recently and I had it rebuilt by a local specialist for less than a third of the cost of a new replacement and I am happy with it.
Cheers,
Jeff.
richg
Aug 7, 2022 12:15 PM
TPorter13
Sep 11, 2021 11:34 AM
sanchez
Aug 7, 2018 11:46 AM
bmcinsd
Sep 1, 2017 02:27 PM
jahlack
XJ40 ( XJ81 )
Jul 30, 2013 02:56 PM
