x300 codes
Old Oct 11, 2025 | 10:28 AM
jmstunts's Avatar
Default x300 codes
1996 xj6 x300, driving along, car stumbles and goes into limp home mode, transmission fault light comes on, get home, shut it off, restarts right away, no issues, no lights.
Next day, driving and car cuts out, no fault lights, but some sort of alert sound goes off, shut car off, restart, no issues, no warning lights.
I ran the ids scan and here are the codes.....ABS C1095, Engine control module P1138, P1315, transmission control module P0727, instrument pack P00EE. Looked up the codes, there were a few solutions wondering if anyone here has ever seen this. I did a screenshot of codes....
Jack M
Old Oct 11, 2025 | 12:24 PM
Parker 7's Avatar
By limp mode you are seeing ? From my understanding the X300 does not have a limp mode , the later V - 8 X308 does
Engine never stalls out to an on the road shut off ?
.ABS C1095 is that special thing with ABS module desoldering of a specific solder joint , many have repaired themselves
Old Oct 11, 2025 | 01:51 PM
jmstunts's Avatar
When it first started acting up, there was very little power and the transmission would not downshit, when I got home and shut it off, it restarted right away, ran fine, no code lights....
Old Oct 12, 2025 | 03:13 PM
Parker 7's Avatar
Wild hair but maybe ,
The speed sensor inside the transmission cross talks with the engine ECU by way of the transmission ECU as the Eng / Trans danse together
The electrical connector on the car's left transmission body can get corrupted and cleaned , the fault usually acures at very low speed coming out of park from reading others
The connector does not remove like a common connector and was referred to as a Daushe connector hense German manufacture ( transmission package in this case )
To remove connector , no jacking required , the barrel must first be moved aft about 1 / 8 inch and only then the top of the connector roteted about 1/ 2 turn top to car's outboard ( counterclocwise as looing from connectors rear )
Pic coming someone made that says 1000 words ,notice the tie wrap gripping the barrel to turn off , no rome for channel locks
Old Oct 13, 2025 | 03:49 AM
katar83's Avatar
Transmission codes are a red herring here, it goes into limp mode because you're driving and the car cuts off for a split second and there's a problem with ignition possibly and the car will always immediately go into limp mode and you'll get the transmission light, as soon as you restart and the car runs fine it will clear the transmission light so you'll need to find out why its cutting off. Obvious first thing is crankshaft position sensor, if all the dash lights flash or the RPMs go weirdly up and down could also be a coil.
Old Oct 13, 2025 | 04:26 AM
jmstunts's Avatar
Thanks for the info, it goes into the shop next week, hopefully they will sort it out.
Jack M
Old Oct 13, 2025 | 04:28 AM
jmstunts's Avatar
Thanks for the info, sounds like you've had this happen, or seen it before, it goes into the shop next week, they have IDS on their Toughbook.
Jack M
Old Nov 3, 2025 | 10:42 PM
Parker 7's Avatar
See page 111 and 121
801S TITLE
Old Nov 4, 2025 | 04:55 AM
jmstunts's Avatar
Thanks....
Old Nov 4, 2025 | 05:00 AM
jmstunts's Avatar
Thanks for the info, I saw in the transmission codes section regarding the light coming on, it says if the engine speed drops below 300rpm, while in other than park or neutral, the transmission light will come on, it will clear when restarted.....just like you mentioned....
Paul1940
Apr 26, 2023 08:32 AM
avanti357
Dec 29, 2022 05:55 AM
rrmillsap
Jun 11, 2018 12:39 PM
Dave2254
May 4, 2014 08:22 AM
Guatejag
May 2, 2008 07:30 PM
