Messages displayed in the speedometer.
Old Apr 25, 2023 | 08:41 AM
Paul1940's Avatar
Default Messages displayed in the speedometer.
Is there a list of potential messages that may be displayed in the speedometer? I am in need of an explanation for two.
1) Cruise control unavailable.
2) Check rear lights.
​​​​​​Neither appears to set the fault code icon.
Old Apr 25, 2023 | 08:47 AM
motorcarman's Avatar
There are DTCs, just not always P codes.
There are also B codes, C codes and U codes.
Find a 'reader' that can access ALL modules.
Old Apr 25, 2023 | 08:55 AM
fmertz's Avatar
This generally means there is an issue with your brake switch. It is a pretty common issue. Your options are to replace it outright, or repair the circuit board by replacing the 2 soldered micro switches. These are pretty standard NC/NO micro switches with several suppliers and part# already identified. On a scale of 1 to 10, the soldering skills required are a 1 or a 2, nothing outside of the ordinary. The part is a pain to reinstall, but again nothing outside of what a determined individual can accomplish on their own. There are MANY posts about this on this forum.
Best of luck, keep us posted.
Old Apr 25, 2023 | 09:20 AM
Paul1940's Avatar
Default Brake switch repair
Can you reference a post that describes the procedure?
Old Apr 25, 2023 | 09:47 AM
Jon89's Avatar
Just type "XK8 brake pedal switch assembly repair" into the forum's search bar and read all about it. As others have said, the very best fix is to replace the two rather flimsy microswitches in the assembly with much more robust ones. Many of us have sourced our new microswitches from mouser.com....
Old Apr 25, 2023 | 04:41 PM
robak's Avatar
had the same problem/combination of fault codes.
As already said: brake light switch.
Old Apr 26, 2023 | 08:30 AM
Paul1940's Avatar
Default Thanks to all who responded
I appreciate your assistance. Looks like I need to find a permanent solution. I am buoyed by the opto couple solution I found in your responses. Again thank you.
Old Apr 26, 2023 | 08:32 AM
Paul1940's Avatar
2003JagStr
Nov 8, 2022 02:04 AM
Dell Gailey
Feb 22, 2018 02:48 AM
Tarik
Nov 2, 2014 02:09 PM
Jagmag
Feb 27, 2012 10:32 PM
The World Tour
Jan 9, 2012 01:35 PM
