X300 disabling alarm system
Old Mar 19, 2011 | 07:34 AM
tag1000's Avatar
Default X300 disabling alarm system
Hi everyone,
the alarm system on my '95 x300 is going nuts.
Maybe a broken door sensor?
Anyway, how do I turn off the alarm system? I could not find anything about this topic in the handbooks.
Any help is highly appreciated.
Best regards,
Julian
Old Mar 19, 2011 | 07:42 AM
tag1000's Avatar
In addition: On my Audi the alarm, once set off, stops by itself after a certain time...on the JAG it doesn't until I unlock/lock the car via remote...is this normal?
Old Mar 19, 2011 | 09:55 PM
SRL1990's Avatar
Default alarm
This used to happen to me ALL THE TIME..I wake up at 12 PM hearing that alarm blaaarrring off. I have 2 key remotes..I was using one for a while and I lost it, so i started to use my backup. Everytime I locked it with my backup the car alarm would go off 5-30mins later..Really annoying. When I found my original I used that again and the alarm stopped going off random times. It was good knowing it worked but really annoying hearing it lol.
Old Nov 16, 2012 | 05:17 AM
Jetze Mellema's Avatar
I have the same question, how do I disable the X300 alarm system?
Old Nov 16, 2012 | 08:08 AM
V126man's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Default X300 Alarm Disable
In the UK the alarm activates a separate sounder. I don't know if this is the case in the rest of the world. The alarm is part of the Security and Locking Control Module (SLCM) which is located in the trunk near the fuel filler and cannot be simply disabled. Furthermore this module must be configured to the car if it is replaced using suitable dealer level diagnostic equipment. The simplest method is to remove the plug at the alarm sounder which on UK models is located underneath the plastic cover at the screenwash filler neck. The alarm will still activate but you obviously won't hear it.
Old Apr 15, 2017 | 06:06 AM
Davey.j's Avatar
Hi. I have a 1995 x300. My alarm doesn't sound however the indicator lights continually flash and the headlights are on. The only way to turn them off is to disconnect the battery.
Has anyone got any suggestions as to the problem ?
Forcedair1
Feb 19, 2020 01:51 PM
42Ajd
Dec 30, 2015 09:45 AM
Bigvettefreak
Sep 6, 2015 04:27 PM
mcdutch
Sep 4, 2015 03:38 AM
philwarner
Sep 3, 2015 10:14 PM
