X300 High idle fixed > ECM fault
Car: X300 4.0 N/A 250^000km
Symptom: From one day to another the idle RPM set at 1400 revs steady.
Daalership with one of the last orig. WDS did a reset which cured it instantly. But: after 2 weeks the 1400revs came back.
Changed the ECM to a secondhand one from ebay. I have now normal idle again and driven 2000km.
As an intermittend fix until I could corner in the ECM i did this: After starting the cold car and engine running at 1400revs I waited until the rising coolant temp made the ECM signalling the idle air control valve to close and gradualy lowering the revs to 900 rpm. At that moment I unplugged the IACV. So I could drive the car without hassle except when starting at cold I had to apply some pedal to keep it alive as idle when cold was about 500RPM.
Hope that helpes anybody pleaged with this famous X300 fault.
Tame Technician
Sep 12, 2012 02:31 PM
