X300 Power Steering not strong enough when idling
Old Jul 16, 2015 | 08:49 PM
smartobject's Avatar
Default Tie Rod Ends
The tie-rod-end should come off when the bolt is removed from the outer end of the tie rod - the part the connects the tie rod to the hub/spindle.
Now, you may need to use a tie-rod-puller tool or a "fork" style tool to separate the tie-rod-end from the hub spindle.
Before taking them off, put some white paint or something on the threads of the steering rack shaft to show where the tie-rod-end comes to when reassembling. That way, you're at least close enough to the correct spot to be able to drive it to an alignment shop.
Old Jul 17, 2015 | 03:48 AM
someguywithajag's Avatar
Thank you for your reply.
That bolt was the problem. I ended up giving it a few wacks with a hammer; that loosened it up. Everything came apart after that pretty quickly.
I do have a question though: the inner tie rods seem to fine but in order to remove them from the rack's core, I had to use a centre punch to destroy their locks (the lock was just an indent that prevented each inner tie rod from unscrewing on its own).
I might be able to use the centre punch to make an indent to make a lock again, should I or should I just replace them with new tie rods?
Best.
Old Jul 17, 2015 | 10:14 PM
I am not sure about that, it's been a long time since I did mine.
I looked through the pdf posted above by cool, but can't make out anything with a punched indent on that shaft.
Old Jul 19, 2015 | 09:40 AM
cool's Avatar
if your tie rod bar are still good, you can reuse them (as long as there is no clearance when moving the ball and socket) Make sure to tighten rod with the proper torque since there is already no lock on the inner end of the rod, still it will not release/loosen itself.
Old Jul 19, 2015 | 07:12 PM
Perhaps it's more clear in the following two pictures: I circled the relevant members.
Attached Thumbnails X300 Power Steering not strong enough when idling-rack-core-indent.png   X300 Power Steering not strong enough when idling-inner-tie-rod-indent.png
Old Jul 19, 2015 | 07:13 PM
Makes sense. Would you happen to know the torque specs?
Old Jun 15, 2016 | 03:25 AM
SD96XJ6L's Avatar
As an update, I flushed removed the old fluid from the reservoir with a pump a couple of time with Amsoil transmission fluid and the car no longer has this issue. I didn't even think about the fact that my fluid could be old and just this little bit of freshening of the fluid helped a ton. I really need to keep doing this but am saving the four quarts I have left for a transmission drain & fill at the moment.
Old Apr 20, 2017 | 09:34 AM
  #28
vandenplas408's Avatar
no DO NOT REUSE THOSE TIE RODS!! ><
Old Apr 21, 2017 | 12:18 PM
I ended up buying a new set. Didn't think it was worth the trouble/risk to reuse those rods
aholbro1
Dec 29, 2024 06:46 PM
Dicque
Sep 19, 2015 12:53 PM
1964Daimler
Sep 9, 2015 11:28 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
