X308 muffler on X300?
Old May 26, 2022 | 03:31 PM
labcoatguy's Avatar
Default X308 muffler on X300?
So we know that Jaguar carried over a lot of their engineering from the X300 to the X308. Does that extend to sharing exhaust configuration? I ask because, at first glance, it looks like there's some similarity to the piping location and mounting points of the rearmost pair of mufflers on both the X308 and the X300, even if the parts numbers and exact pipe routing differs a bit. I've been trying to find replacements for the rear boxes on my X300, and the equivalent X308 part seems both cheaper and more plentiful. It'd be great if anyone who's tried interchanging them can speak to whether or not this is a possibility, or if they differ enough for it not to be doable. They seem to share the same rearmost exhaust mounting bushing (the L-shaped bracket with rubber mount points) so there seems to be some hope.
Old May 27, 2022 | 01:18 AM
someguywithajag's Avatar
I believe the last pair of exhaust silencers + tips have the exact same form factor but I don't know if the internals are the same. Maybe the insides have different sound characteristics... However, I did find this listing on eBay by Simply Performance:
https://www.ebay.com/itm/224423281977
"This is a listing for a pair of X308 XJ8 XJR rear exhaust boxes and tips. These are made from a very high quality 304 stainless steel. They are a direct fit onto any X308 1997-2002, these also fit X300 XJ6."
Old May 27, 2022 | 03:56 AM
OxfordJoe's Avatar
Default X300 rear exhausts
Loving the £619 stainless rear boxes and tips.
My 96 X300 3.2 came with a rear box delete which made too much of a drone.
A pair of mild steel boxes were £130 from eBay but I still need a pair of tips at a reasonable price - the old ones had been welded in to the straight pipe. Mean Scotsman that I am
Interesting to see the X308 boxes look like a fit.
Old Oct 5, 2022 | 11:53 AM
labcoatguy's Avatar
Turns out X308 parts cars are more scarce than I thought, yet somehow there are still many XJ40 parts cars around. Has anyone tried to see if XJ40 exhausts also fit an X300?
Old Oct 31, 2022 | 01:20 PM
labcoatguy's Avatar
Update: after some annoying wrestling with rust, I can confirm that X308 rear mufflers fit perfectly on an X300. Thanks, Jaguar, for leaving the exhaust routing and mounting points the same.
Blue XK
Dec 6, 2015 09:27 PM
fmfz12007
Oct 31, 2015 11:49 PM
Bumbazor
Apr 15, 2015 07:45 AM
J_B_1
Mar 28, 2015 07:20 AM
BadCat
Feb 1, 2011 10:12 AM
