XJ6 96 Sunroof issue
Old Apr 30, 2008 | 05:56 PM
clubmia85's Avatar
Default XJ6 96 Sunroof issue
hello everyone, I noticed that when I go to open the sunroof it makes a noise like its struggling to open, but opens fine. Then when I go to close it automatically it will reach about 75% of the way and then reopen again, but if I go to close it manually by holding the switch it will close all the way. I have just noticed that when I put the tilt up I looked from behind my car and saw that the right side was lower than the left, and I saw that the plastic part holding it up on that side was broken off, does anyone know where I cna find that part, or will I have to redo the whole roof? And also, is that what is causing it to reopen everytime? Somone please help me out, thanks.
Old Apr 30, 2008 | 08:51 PM
jag_genius's Avatar
Default RE: XJ6 96 Sunroof issue
the part that is broken is called a slider.. you will have to buy a new left and right hand pieces.. kinda long to replace them..
Old Apr 30, 2008 | 09:07 PM
clubmia85's Avatar
is that part that I need called a tilt and slide mechanism? Its only broken on the right side not left. And if it is that part I had them replaced a little over a year ago.
Old May 1, 2008 | 08:23 AM
ken@britishparts.com's Avatar
That's it.
Old May 1, 2008 | 11:38 AM
clubmia85's Avatar
how did it break off so easy, I just had it replaced last year.
Old May 1, 2008 | 12:17 PM
Make sure the interior cover isn't binding in the track. These do fail regularly, but shouldn't let go that fast.
Old May 1, 2008 | 06:50 PM
jag_genius's Avatar
no never seen them go that fast... maybe panel got caught as ken said..
rusty37
Apr 5, 2020 07:40 PM
carcycle
Sep 7, 2015 04:14 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
King Charles
Sep 3, 2015 12:40 AM
