xj6frontsprings
Old Aug 6, 2014 | 02:34 PM
baillie-evans1950's Avatar
Default xj6frontsprings
hi got to change 2 front springs on m7 xj6 and need to borrow spring compressor tool if anyone got one to lend please
Old Aug 6, 2014 | 02:36 PM
can pik up 30 mile radius
Old Aug 8, 2014 | 02:39 AM
theJPster's Avatar
30 mile radius of...?
Got one in Mid-Cambs, UK.
Old Aug 8, 2014 | 01:18 PM
FireCrow's Avatar
Is that Ipswich UK? Unfortunately, I haven't got the Jag specific one, and the ones I have are not up to the task...
Old Aug 8, 2014 | 07:39 PM
Don B's Avatar
Hi baille-evans1950,
Below is a link to a photo album showing how I built my own spring compressor based on various home-brew designs created by others. A lot of guys have just used a stack of heavy washers with an O.D. of about 2-1/4 inches instead of the large steel ball I used, based on a design by Win at the Jag-Lovers forum. Threaded 20mm threaded rod and high-strength dowel pins can be purchased from many industrial supply houses:
Welcome to Jag-lovers - Members Photo Viewing Page
Cheers,
Don
Old Aug 14, 2014 | 10:22 PM
avioni's Avatar
i just did mine with threaded rods. 4 pieces of m8 - 1.25 x 12" with 2 washers and 1 nut per bolt. remove one of the spring pan bolts and replace with one of the threaded rods, do this for 4 of the spring pan bolts. then start lowering the pan slowly. its very time consuming but works if you cant find the correct part.
