XJR springs on an XJ6?
Old Oct 2, 2010 | 12:25 PM
jsomogyi's Avatar
Default XJR springs on an XJ6?
Would this work ok if im riding on new monroe sensatrac shocks? Im thinking about purchasing a used set of XJR springs for 120 because my XJ6 has too much body roll and bounce.
Old Oct 2, 2010 | 12:31 PM
Doug's Avatar
IMHO, I don't see any reason why the XJR springs wouldn't work
Old Oct 3, 2010 | 02:51 PM
jaggachafen's Avatar
Of course they will. But i´m not sure you will be satisfied.
Pretty sure that Eibach has springs for your car and they will almost certainly make a different
The XJR has a pretty good body roll aswell.
Question: Som of these cars have a rear antirollbar have yours?? if no there should be an easy install
Old Oct 3, 2010 | 02:53 PM
http://www.autocarparts.com/part/179/329/
Old Oct 3, 2010 | 05:09 PM
jsomogyi's Avatar
I've heard that H&R is a great blend of handling and ride quality. What are they like compared to Ebiachs?
Old Oct 3, 2010 | 08:38 PM
Doug's Avatar
The XJR and Sport models have the rear bar and a larger front bar. I think this probably more significant than the springs
Old Oct 3, 2010 | 08:39 PM
Doug's Avatar
Since X300s have non-adjustable front camber I'd be a bit leery about lowering the suspension.
Old Oct 4, 2010 | 12:09 AM
Yess it ads som camber but not more that you can live with.
You need to adjust the alignment after shifting the springs though
HR and Eibach is to my knowledge the samething or atleast very similar
Old Dec 18, 2012 | 09:47 PM
aldol's Avatar
Default springs xj6 and xjr
i could be wrong but the springs are the same according to rockauto
Old Dec 18, 2012 | 11:36 PM
Doug's Avatar
Just as with the shocks, the aftermarket suppliers don't offer equivalents for all the OEM choices.
Old Dec 20, 2012 | 03:15 PM
XJRengineer's Avatar
Doug is absolutely right. If you check the Jaguar Classic Parts website you can see that the XJR has different springs, dampers, anti-roll bar and even anti-roll bar bushes to other models. The parts are phisically interchangeable. There is no reason that you couldn't make an XJR ride and handle like and XJR.
If you want your car to handle even better than an std XJR then you should fit my rose-jointed (heim-jointed) front anti-roll bar drop links.
Forcedair1
Sep 8, 2025 01:57 PM
rusty37
Apr 5, 2020 07:40 PM
Tar
Sep 6, 2015 11:24 AM
