XJR6 front crossmember removal plus throttle body
Old 07-19-2023, 05:36 PM
willbot's Avatar
Question XJR6 front crossmember removal plus throttle body
I need to clean out the throttle, which is an absolute pain on the XJR6, so I was wondering if I could do in the same operation as swapping out the front crossmember?
Engine mount bushings are more than due as well, so I was thinking I'd support the engine with a hoist while the crossmember and do the bushings as that's being swapped out.
Since it's roughly near where I'd need to be to get the throttle body out, I was wondering if it'd be way easier to do with the crossmember out of the way? Thank you
Old 07-19-2023, 07:11 PM
Parker 7's Avatar
The engine mounts between the left and right are different and there seems to be a problem in sourcing
There is a TSB on breather gas separator and a separate catch can mod components
Old 07-24-2023, 05:27 PM
countyjag's Avatar
The subframe being out of the way would certainly help. The throttle body on the supercharged cars is best approached from below, and can be removed with the subframe in place. Long arms help!
Crandell
03-21-2019 11:44 PM
fredd60
03-10-2019 09:01 PM
Daim
11-12-2016 10:07 AM
OttawaX300
06-07-2012 09:21 AM
OttawaX300
05-29-2012 06:27 PM
Quick Reply: XJR6 front crossmember removal plus throttle body
