ZF 4HP22 transmission service manual
Old May 27, 2019 | 11:57 PM
howitzer's Avatar
Default ZF 4HP22 transmission service manual
Hi, guys. Does anyone have an 4HP22 manual with all the part numbers in PDF or some other digital format? I want to make a servicing for my gearbox and that includes also the removal and cleaning of the valve body. I want to pre-order all the necessary gaskets and maybe other tiny parts, but I don`t know the part numbers. Can anyone help, please?
Old May 28, 2019 | 02:18 AM
A quick Google found this, maybe of some use.
https://www.scribd.com/doc/254865544...-Repair-Manual
Old May 28, 2019 | 01:11 PM
howitzer's Avatar
I`ve quick Googled this myself and there`s nothing about the valve body disassembly and nor are the necessary gaskets mentioned that are required when removing the valve body.
I guess, ZF is treating the valve body as single, replaceable part and repairs are not anticipated for this part.
Here`s a great writeup though, about 4HP22 maintenance, I want to perform the same operation as the bmw owner did in his article, that`s why I need spares.
ZF 4HP22E Valve Body Rebuild
Old May 28, 2019 | 07:21 PM
Don B's Avatar
Hi howitzer,
I'm attaching some of the references I have on the 4HP22 and 24. I also have another repair manual and another parts manual but the files are too large to attach to a post. PM me your email address and I'll send them to you.
Cheers,
Don
File Type: pdf
File Type: pdf
Old May 29, 2019 | 12:08 AM
howitzer's Avatar
Awesome - will have a closer look at these!
salmise
31
Jul 8, 2024 08:12 PM
Taurus
Nov 23, 2018 03:28 AM
madgrey
XF (X260)
Nov 10, 2018 10:49 AM
imagineaudio
Oct 28, 2010 06:20 PM
