“Noisy” dashboard
Old Feb 14, 2019 | 10:52 AM
King Charles's Avatar
Originally Posted by Ophitoxaemia
My defroster plastic just below the windshield does not fasten down all the way, will creak when it's cold. Unsure how to access to fix it.
You need to gently pull up on it & see if it is even attached to the clip holder, as many like mine break off @ that point so in effect they are not secure.
Old Feb 14, 2019 | 10:28 PM
aquifer's Avatar
I have used pressed foam rubber, the stuff that they put on the corners of windshields when they ship them. I got a few from a local body shop and cut a few pieces the size i wanted. They just throw them away, so didn’t cost me anything. My dash is black, and these were black, so they weren’t noticeable.
Old Feb 16, 2019 | 12:42 AM
Jeroen's Avatar
Lots of good tips and suggestion already. Let me add my experience. I was getting some very annoying noises from the front of the dashboard as well. Close to the windscreen. I pried out the vent piece that holds the sun sensor. Turned out that the clip holder underneath the windscreen in which the vent fits was broken. So it just was not holding the vent tightly anymore. Managed to glue it with some super glue. Had to experiment with different glues to find the one that worked on these plastics. So far so good, it has held for nearly ten years, fingers crossed!
Jeroen
Ronco1
Jun 4, 2025 02:46 AM
drmicro
Apr 20, 2008 08:06 AM
whitestype
Mar 17, 2008 04:38 AM
certifiedimports
Nov 6, 2007 10:41 AM
XJ40ish
XJ40 ( XJ81 )
29
Oct 14, 2007 04:05 PM
