'00 VDP Cat Failure - PO420
Old Jun 12, 2014 | 01:22 PM
Oliver9218's Avatar
Default '00 VDP Cat Failure - PO420
How common is cat failure on a '00 XJ8 VDP? I just got it about 4k miles ago. It has 104k miles. CEL came on yesterday in traffic. Cat failure code PO420. I cleared the code, but I know a cat replacement is coming soon... Anyone else have to deal with this?
Old Jun 12, 2014 | 05:13 PM
motorcarsrandy's Avatar
I did a good BG 3 part fuel system service. Ran through injectors, Throttle-body and 44k in tank and it cleaned mine. i had one that was lazy. That was 20k miles ago and all is well.
There are some methods that will clean them. I have seen where they pour a gallon of turpentine in fuel tank and if does not work they soak it in a pale of soapy water.
Old Jun 12, 2014 | 05:44 PM
Oliver9218's Avatar
Nice to know. I'll give the BG a try.
Thx.
Old Jun 12, 2014 | 08:05 PM
Rlover's Avatar
I recommend 2 cans of seafoam in the gas tank and half gallon of Lucas fuel treatment as well then a full tank over, then floor it. Get it up to 105 then floor it to 130. Repeat four or five times. You will never see that code again. \0/
Old Jun 12, 2014 | 09:09 PM
sparkenzap's Avatar
Otherwise known as an "Italian tune-up"
Old Oct 24, 2018 | 05:15 PM
iownme's Avatar
brutal.... who sells the O2 extender?
tried another oxy sensor and that P2a01 came back again so the big daddy mini cat might not be a solution
aholbro1
Dec 29, 2024 06:46 PM
perezal
Dec 24, 2015 04:17 PM
perezal
Dec 24, 2015 04:16 PM
kevinl
Sep 24, 2015 08:25 PM
mrplow58
Sep 9, 2015 11:27 AM
