'01 XJ8L Brakes
Old Jul 5, 2009 | 05:39 PM
jaginblack's Avatar
Default '01 XJ8L Brakes
My recently acquired '01 XJ8L needs front brakes (62k miles). It has a slight squeal and I can feel some grooving on the rotors, so I am expecting to need new rotors when I take it in and would like to source parts myself to avoid a sore rear, if possible.
Can anyone recommend a good cost/quality rotor? Looking online I see Brembo rotors at a good price but don't know if that is part of a system or just replacement. Do Brembos require special pads. I just want good braking at reasonable cost.
Thanks for any pointers!
Old Jul 5, 2009 | 07:02 PM
wazari's Avatar
Brembo makes a quality standard replacement rotor. If you plan on keeping your car for a while I recommend getting them cyrogenically treated for a much longer life.
www.frozenrotors.com
Also get a set of quality pads. Performance Friction and Disc Italia are the only two companies that I know of that make a high compression molded pad for the X308's. Other companies such as Hawk. Akebono, etc also make good quality low compression molded pads that last longer and don't dust as much as stock pads.
Old Jul 6, 2009 | 05:27 AM
jaginblack's Avatar
Thanks for the tip and the link - I think that's the way I'll go.
Old Jul 6, 2009 | 09:02 PM
jaginblack's Avatar
Are there brake wear sensors on an '01 XJ8L? I have been asking around for estimates on front rotor and pad replacement but they are saying they have to check the sensors before they can give an estimate. Are they pulling my leg?
Old Jul 7, 2009 | 02:19 AM
wazari's Avatar
No sensors on these cars.
jdzubas
Oct 4, 2015 09:14 AM
flyrr100
Sep 29, 2015 03:47 PM
xjrjag
Sep 24, 2015 10:08 PM
wannajag
Sep 22, 2015 08:29 PM
'05 Gold XJ8L VDP
Sep 18, 2015 07:15 AM
