03 xj8 tranny problems. Stuck in 4th
Old Mar 22, 2014 | 07:21 PM
socalXJ8's Avatar
Default 03 xj8 tranny problems. Stuck in 4th
Hi
Starting today my car started to have some transmission problems out of the blue. Drove fine in the morning but later when I drove back home the tranny started to act up.
At first it would rev in gear and not engage the gear for a second and then would jerk as it went into gear. It would do this 1-2 then would skip 3rd and go to 4th.
After doing this for about 3 stop and goes, it now is only in 4th it feels like. It won't shift down to anything below 4th at a stop. I can still drive it but it's in 4th so I feels like a slug up until 40mph. I didn't try giving it some gas to have it downshift fearing that would be bad. I have tried using the J shifter from 2-4 and it doesn't shift down still.
At a stop I can change from P or N into D or R with no unusual delay(takes about the same amount of time as normal before the problems, approx 1sec). No jerks or loud noises when changing P R N D.
I have no idea where to start to diagnose this problem. I've read it could be as easy as low fluid, which I see some wet spots under the car on the tranny or the tranny computer. I'm about to go jack up the car and take a look.
What should I do to start looking for a solution?
Old Mar 22, 2014 | 08:20 PM
socalXJ8's Avatar
Looks like I am leaking or have been for a while.
tomsjag
Jun 10, 2023 10:02 AM
Rlover
Mar 30, 2016 10:04 PM
neruda
Oct 18, 2015 01:19 PM
TreVoRTasmin
Sep 16, 2015 08:14 PM
ratgawd
Sep 16, 2015 04:15 PM
