transmission fault, won't change gear
Old Mar 21, 2014 | 12:10 AM
vincent661983's Avatar
Default transmission fault, won't change gear
ok,some may have read my recent issue. i changed the entire shifter assembly
now the car receives transmission fault and yellow warning light is on
car running 5k rpm at 50 mph and it wont shift down
FYI,mine is xjr with M-benz 5 speed.
too many issues one after another every month, i almost need to give up this car
please help
Old Mar 21, 2014 | 05:21 AM
motorcarsrandy's Avatar
Sounds like the linear switch is defective or mis adjusted. You stated you changed shifter. Could be related. Has to have an XJR shifter on XJR. Check and see if you have a P0705 code stored. If so, it is linear switch related.
Old Mar 21, 2014 | 08:00 AM
I confirmed with the seller 3 times that shifter was coming out from a XJR
so I found it is called "limp mode" now, car cant shift out of 2nd gear
Old Mar 22, 2014 | 08:40 AM
did it come complete w/ linear switch on side? If so that one could be bad. You may want to check your connections if good swap that part. The one where shift cable attaches.
those switches are known to fail causing the behavior you have.
If the shift position marks do no t light in any position, switch is suspect.
BTW 2000 year models had a bulletin re: failure. Is your check engine light staying on. If so check codes if not there could be a pending code. Look for P0705.
Old Mar 22, 2014 | 10:59 AM
yesyes,none of gear lights lid up and i called my local jaguar dealer and mark a English gentleman told by most likely something to do with the linear switch or misalignment of the shifter cable.
Old Mar 22, 2014 | 09:41 PM
finally i was able to make it work and communicating with the gearbox.
but i cracked the trim housing now those 2 bottoms are dancing around
JarodL
Mar 7, 2024 01:39 AM
cissdm
May 3, 2016 06:02 AM
arnoldmilk
Sep 3, 2015 07:42 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
XFR_Gold
Sep 2, 2015 12:24 PM
