03 XJR: Sporadically fails to start
Old Jun 10, 2013 | 01:54 PM
SuperSport's Avatar
Originally Posted by Sean B
looking at the video, I think you could have a bad/broken connection/earth in the wiring on the steering column.
It would need the wheel off and to check each wire on the wiper stalk, ignition barrel, clock spring etc. Whatever it is, it's creating an issue with the bcm.
I've posted a number of times on the r&r of steering wheel, only thing to point out is drop the battery before as it's good practice in case of airbag deployment. It's a simple job.
+1 on this. I'm thinking Ignition Switch or wiring leading to it.
Old Jun 12, 2013 | 07:36 AM
princemarko's Avatar
So now... everytime I do anything like having the ODB reader on or checking the battery, the car doesnt start. I have to put touch the negative and positive, then lock/unlock the doors. Maybe its a remote alarm issue?
Old Jun 12, 2013 | 09:41 AM
Sean B's Avatar
The obd reader port is on the dash/column loom. How do you check the battery?
Have you any issues with the rear lights? because the security locking module controls them, there might have been an issue with the flashing additions you fitted, a burnt out component on the circuit board within the slm.
Have these quirks been a recent thing? like after you fitted the flashers?
Old Jun 12, 2013 | 02:41 PM
when I went to Autozone, i had them check the battery voltage... as soon as he finished, the car wouldnt start.
The blinkers are off now, the only other thing i noticed is the transmission delaying on WOT recently.
I am nearly going to take it to the dealer, this is becoming too complex of an issue.
I have new bushings and shocks going in the front end, which by the way, i disconnected the CATS module...
Old Jun 12, 2013 | 02:53 PM
Sean B's Avatar
Don't be concerned about the unplugged module, it's non cats' now, at least that's how the car's system sees it.
Lighting additions are now off the car, and the connections are super soldered and shrink wrapped? (by this I mean the twist and tape method will not do)
Check the column wiring.
To remove the steering wheel, lower and extend for max space, you need to unbolt the airbag from the back 2 x torx, drop the battery, a highly remote chance of earthing the wires and it goes off...
once the bag's out of the way, you'll see cruise and vol wiring, disconnect them and unbolt the wheel by the centre boss. Wheel lifts off. Now you can inspect the stalks wiring. The upper and lower cowl removed exposes the ignition wires. This is where I would start. It's an 03' (02' to me)for christ's sake!
You know what happens when that car goes to the dealers....I've seen 2 big bills....
dsnyder586
Dec 29, 2024 07:39 PM
Bowman
Sep 15, 2015 06:54 AM
Mosers63
Sep 6, 2015 02:53 PM
jaguarbill
Sep 5, 2015 11:43 AM
rachelstr
Sep 3, 2015 12:59 PM
