03 xjr: Where is the ecu located?
Old Apr 17, 2011 | 05:01 PM
Viapa's Avatar
Default 03 xjr: Where is the ecu located?
I am in the process of having my ECU recalibrated by Eurotek Designs. Can anyone tell me where the ECU is located in the XJR.
Old Apr 17, 2011 | 10:56 PM
CharcoalJag's Avatar
I have a 2001 XJ8. My ECU is located under the hood, passenger side next to the firewall. Remove the cover for the right hand (passenger side) hood latch. Under it you should see a cover held on by 4 torx screws. Remove this cover and lift out your ECU. CharcoalJag
Old Apr 18, 2011 | 06:33 AM
test point's Avatar
Be sure to disconnect the battery before removing the ECM connector. You don't want to let the smoke out.
Sleestak
Aug 17, 2022 11:22 AM
rominempire
28
Oct 8, 2020 10:39 AM
damienedwards
Nov 22, 2015 10:51 AM
zoozth
Sep 29, 2015 07:28 AM
