06 XJ8 overheating issue
Old Jul 28, 2022 | 11:47 PM
Alex3535's Avatar
Default 06 XJ8 overheating issue
06 XJ8:
The coolant spilled out after I forgot to put the cap on the coolant reservoir and drove it couple miles. When I realized I filled the coolant and ran it again and the car overheats now.
Heat doesn't work.
after shutting it off the fans keep running for couple mins and the coolant is real hot when I try to open. Heater doesn't work too.
Your suggestion is needed where should I start from? Thanks
Old Jul 29, 2022 | 07:57 AM
xalty's Avatar
bleed the system now
Old Jul 29, 2022 | 08:56 AM
motorcarman's Avatar
This question should be in the correct forum section.
https://www.jaguarforums.com/forum/x...-x350-x358-28/
Old Jul 29, 2022 | 08:59 AM
RandyS's Avatar
It may be a good time to check the thermostat and flush the system. I doubt a couple of miles would cause what you are reporting.
Old Jul 29, 2022 | 10:23 AM
Alex3535's Avatar
Do they have a bleed valve? Or what will be the simple way to bleed it? I am not a mechanic but can do the basic things. Thanks
Old Jul 29, 2022 | 05:06 PM
RandyS's Avatar
Alex, like motorcarman indicated, it may well be better answered in the correct forum for your particular model Jaguar.
romroc
Oct 31, 2020 04:05 AM
Nicholas Tomsyck
Jul 9, 2020 08:06 PM
jaguars4r
Aug 4, 2012 10:21 AM
black vanden plas
Jun 16, 2010 09:15 AM
Jaybo242000
Aug 15, 2008 09:01 PM
