1998 XJ-8 some questions
Old Aug 26, 2009 | 07:59 AM
CharlesF's Avatar
Default 1998 XJ-8 some questions
I have recently bought a 1998 XJ-8 and have a number of questions that perhaps I can get help on?
1) Where can I download a Driver's Manual? I have the 2 Jag workshop CD's
2) There appears to be some slack in the transmission. When I pull away there's a slight delay before it "takes". Also if I park on a slope the car rolls forward a few inches before it stops
3) On the highway the ride is quiet and as smooth as silk. However on bumpier roads there a sort of rattle or klunking noise from the rear of the car.
Thanks in anticipation
Charles
Old Aug 26, 2009 | 04:07 PM
CharlesF's Avatar
Google found me the drivers manuals
Old Aug 26, 2009 | 05:42 PM
wazari's Avatar
2) could be a number of reasons for the slight delay, could be normal. Slight is a subjective term, also how many miles on the car? Maybe it needs a transmission service. Use the parking brake to hold a car on a hill. An automatic transmission is not designed to replace a parking brake. Set the brake first and then put the transmission in park.
3) again could be a number of things, differential, cv (half shaft) joints, exhaust hangers, loose jack or spare or battery in the trunk, etc.
Old Aug 27, 2009 | 05:08 AM
CharlesF's Avatar
Thanks very much. I tried the handbrake out on a slope this morning, it doesn't hold the car. Ideas to fix?
I'll check under the car for exhaust hangers etc. but there's nothing loose in the trunk (battery etc)
Charles
Old Aug 27, 2009 | 05:29 AM
sparkenzap's Avatar
Charles:
Its hard to recognize how big a problem from a "klunk" description. One man's tap is another's klunk!. I would raise the car on jack stands and check the play in the rear wheel by rocking them and pushing and pulling axially. If you've got more than 3-4mm movement, I would get after the bearings pretty quickly. Then using a pry bar or a 4 ft 2x4 with a helper you can try to find what is moving. Most of the time I can find what I call a "klunk" that way, but I seldom find my "tap". That has generally required lots of disassemby or testing. Bearings (wheel or diff), bushings, and the other stuff wazari mentioned (or a beer bottle in the trunk) are all possible. When I bought my XJ6, somebody had not tightened the caliper and it clunked on braking!
Old Aug 27, 2009 | 08:08 AM
CharlesF's Avatar
Thanks Ross
The guy I bought it from said it could be the rear shock bushes? But what you say sounds a good start, something for me to look into this coming weekend
Charles
Old Aug 27, 2009 | 08:37 AM
sparkenzap's Avatar
That would be another good bet, although you read more about front shock bushings. Thge rear shocks on that car are not the easiest to r/r, but there is plenty here and at jag-lovers archives about how to do it.
Old Aug 27, 2009 | 09:30 AM
wazari's Avatar
Charles
Parking brake probably just needs an adjustment, tightening of the cable underneath.
Old Aug 27, 2009 | 03:37 PM
CharlesF's Avatar
The best way I can describe the noise is as if there was a heavy piece of steel loose in the trunk (but there isn't of course)
Old Aug 28, 2009 | 08:58 AM
57loboy's Avatar
I think that qualifies as a "klunk" for sure!
Old Aug 28, 2009 | 10:32 AM
SuperSport's Avatar
Is it always while you are moving? How are you and your wife getting along? Could it be her banging on the trunk lid?
DrTripp
Mar 22, 2020 09:33 AM
Rlover
Mar 30, 2016 10:04 PM
RoyLittle0
Sep 17, 2015 01:05 PM
gold59
US Lower Atlantic
Sep 16, 2015 06:27 AM
jaggermang
Sep 8, 2015 07:07 PM
