1998 XJ8 Radiator hose issues
Old Mar 26, 2013 | 08:15 PM
Tena Herbert's Avatar
Default 1998 XJ8 Radiator hose issues
i have a 1998 xj8 and i am having issues the top radiator hose keeps popping off we have reploaced the thermostat and the radiator pressure cap and it still is doing it also new clamps for hoses if any one has a solution please let me know nearest dealership quite awways away and not very responsive for help
Old Mar 26, 2013 | 10:22 PM
Moved for you...........Hopefully you get a better response
Old Mar 27, 2013 | 03:36 AM
Welcome to the forum Tena Herbert,
1. Even a new Thermostat can be faulty so worth checking it definitely does open. Also that the 'giggle pin' is at the top:
This allows air to bleed and some coolant to pass if the Thermostat is closed.
2. Did you check the Water Pump? Impeller blades can fail on the early pumps.
3. blocked Radiator - either internally or the matrix.
4. correct coolant - mixing early green and later OAT Long Life coolant causes a gel to form which can block the system.
5. does the Heater work? There's a small electric pump in the system that aids circulation of coolant to the Heater. These can fail.
If the correct coolant is circulating properly, there could be a Cylinder Head gasket problem. This can sometimes, though not always, lead to coolant contamination in the oil or vice versa. A compression check is the way to test for Head or gasket problems.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum.
Old Aug 21, 2013 | 07:05 PM
mclrky69's Avatar
Did you ever resolve this issue? I have the exact same problem with my 2003 XJ8
Old Aug 21, 2013 | 07:18 PM
That would be good to know.
Member Tena Herbert hasn't been back on the forum since five minutes after posting the question.
Old Jun 3, 2014 | 08:51 PM
mclrky69's Avatar
Resurrecting an old thread, I had the exact same problem with my 2003 XJ8.
What I have done so far is replace the plastic OEM thermostat housing with the Welsh Enterprises aluminum model, with new thermostat. So far no more popped hoses. I did still have a leak, so replaced the lower rad hose today.
Fingers crossed!
Old Jun 4, 2014 | 07:41 AM
JimmyL's Avatar
I had my rad hose blowing off. The electric cooling fans had blown their fuses. Once they were working, no more problems. On a '98, the water pump is highly suspect if it has never been replaced.
JarodL
Mar 7, 2024 01:39 AM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
obwoodie
Sep 3, 2015 07:45 PM
arnoldmilk
Sep 3, 2015 07:42 PM
OkieTim
Sep 2, 2015 12:48 PM
