1998 XJ8 sterring column issue
Old Aug 7, 2009 | 06:55 PM
nahidik's Avatar
Default 1998 XJ8 sterring column issue
I have just bought a 1998 XJ8 from an older fellow who bought it new. It only has about 45K miles on it and is in very good shape.
The one problem I have is the power steering column has an issue when I push the adjuster button to move the steering wheel up. It barely moves and an audible click behind the clock happens. It works smoothly in all other directions. I figure it must either be the switch or a relay that is tripping. Any advice.
Also my local euro car mechanic/dealer told me the 1998 XJ8 engines where no good and I should expect it to blow up. I checked dealer records and found it had the air flow meter replaced, the timing chain guides upgraded and the transmission overhauled. Your opinion and input will be appreciatged.
Old Aug 8, 2009 | 12:33 AM
poboyblues's Avatar
Steering column tilt motor stuck. Replace.
Bcrary3
Sep 12, 2021 05:41 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Rlover
Mar 30, 2016 10:04 PM
tberg
Sep 7, 2015 07:32 AM
laserguy
Sep 3, 2015 02:02 PM
