1998 XJ8 upper wishbone bushings
Old May 3, 2020 | 05:33 PM
Vinman's Avatar
Default 1998 XJ8 upper wishbone bushings
Having trouble getting new upper wishbone bushings in. Does anyone have some pictures for a install? are they suppose to just press in? Thanks Vinman.
Old May 3, 2020 | 06:39 PM
Highhorse's Avatar
This is from the X308 Workshop Manual. There's a couple links around here to download it from another source. The file is to large to post here.
I left the side bar on the 1st one for search reference after you download it. But these alone may help you if that's all you need.
Old May 4, 2020 | 10:58 PM
Don B's Avatar
Hi Vinman,
The upper control arm bushings, Parts 2 in the diagram below, just press in to the outer ends of the control arm bores. Before you try, be sure to clean any rust or grime from the bores. A good trick is to put the bushings in the freezer for 30 minutes before you install them to slightly shrink their diameter. Another trick is to use a little soapy water as a lubricant.
A C-clamp or bench vise and a suitably-sized socket can be used as a press if necessary. It is not advisable to try to tap the bushings in with a hammer due to the risk of damaging the rubber-to-metal bond.
Cheers,
Don
blindside
May 17, 2018 09:34 AM
Dr John
May 1, 2017 12:23 AM
hilaryv215
Sep 22, 2014 05:57 PM
andypreston
May 6, 2013 11:56 AM
