1999 Jaguar XJR hose name??
Old Apr 30, 2018 | 10:07 AM
David Garcia's Avatar
Originally Posted by GGG
David,
I had to Google that to find out whether to BAN you or THANK you.
THANK YOU,
hahahaa 😂
Old Apr 30, 2018 | 10:21 AM
M. Stojanovic's Avatar
Originally Posted by David Garcia
Got another hose runs to the similar place, need more help with this.
Basically, you should just follow the parts diagram I posted earlier. However, to verify all connections you will have to remove the throttle body. Not difficult but there are two thin coolant hoses you have to disconnect - one at the left side, easy to see and disconnect; the other is at the right side, a short elbow-hose under the TB.
The main point for the vacuum supply is a thin port at the left side of the intake elbow, roughly where the line from no. 7 on the diagram points (I don't think you can see it without removing the TB). A fairly short hose (11) goes from this port to a plastic "T" near the bypass valve where the second branch of the T is connected to the bypass valve by a rubber elbow. The third branch of the T is where you should connect the long hose from the cross under the purge valve. This hose is shown as very short on the diagram (12) but it is the long one.
Old Apr 30, 2018 | 10:49 AM
Is this what you mean?
Old Apr 30, 2018 | 12:25 PM
heres a better video
JimC64
Sep 22, 2025 02:52 PM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
sjuraud
Aug 28, 2010 02:11 PM
JimC64
Sep 10, 2009 12:44 PM
