1999 Jaguar XJR Rear Rattling Noise
Old Aug 4, 2012 | 09:53 PM
KSeferi's Avatar
Default 1999 Jaguar XJR Rear Rattling Noise
Every time I drive sometimes I hear this weird rattling noise it seems to be coming from the back of my car near the trunk. It's not really loud but definitely noticeable when the radio isn't on too loud. The car has 81k miles, it handles very well and I got the beauty for only $5,500! Any help would be absolutely appreciated since I wanna solve any problems before they get too expensive! Thanks to anyone who helps in my dilemma.
Attached Thumbnails 1999 Jaguar XJR Rear Rattling Noise-463521_389706161068380_499158311_o.jpg
Old Aug 4, 2012 | 10:02 PM
CalicoJack's Avatar
Default Rear damper bushes
I had a similar problem with mine at it drove me nuts. I took it to my Jag Guv'ner and he knew what it was without driving it. The upper and lower damper bushes wear out quickly and it a laborious task in removing and replacing (springs have to be compressed etc.)
Well worht getting it done though.
Grant
Old Aug 4, 2012 | 10:13 PM
KSeferi's Avatar
Lord, how much money did he want? And if i don't get it done will it damage the car in any way?
Old Aug 5, 2012 | 12:53 AM
CalicoJack's Avatar
Default About 600 AUD supply and fit
Needs to be done. You will have pooor handling, uneven tyre wear and bump steer because the suspension movement is poorly controlled
Old Aug 5, 2012 | 09:38 AM
SuperSport's Avatar
Hmmm. I was thinking body in the trunk...
Old Aug 5, 2012 | 09:47 AM
KSeferi's Avatar
The tires look amazing on the car, there is light wear but nothing that would point out a major suspension problem. I think it may be loose bolt on the strut somewhere.
KSeferi's Avatar
Also the handling is immaculate.
Old Aug 10, 2012 | 01:18 PM
KSeferi's Avatar
So the struts on the rear were worn down (apparently they last about 60k miles because of the car weight) , I purchased the rear set (lifetime warranty) on eBay for about $150, had the local mechanic install them for $100. Quick and cheap fix.
Rupesh
Mar 25, 2016 03:33 PM
BlacXJRcat
Aug 28, 2015 07:10 AM
Carl Cooper
General Tech Help
Aug 27, 2015 04:36 PM
Zues
Aug 27, 2015 12:02 AM
souldoubt
Aug 25, 2015 08:15 PM
