1999 VDP J gate locked
Old May 13, 2015 | 05:42 PM
Smithfamily's Avatar
Default 1999 VDP J gate locked
Greetings! Fairly new to the "Jag Community", purchased a beautiful 1999 Jag VDP XJ8, madeira red and AWESOME! Noticed a few weeks ago that the key when turned did NOT engage starter immediately? Having had a Mercedes SL600 with the delayed/auto start, this did not cause alarm. Then one morning (Part time use) I went to start, all dash lights lit, nothing, all went off, and wiper stroked, then started?
Today, started immediately and I could NOT engage J gate from park to reverse? Brake applied. Fortunately, after research here on first problem, I was educated to remove star screw and insert key to disengage shifter (J gate) Put the old girl away into garage, as I am headed to Barbados for a week.
Help? Advice?
Also, the gas shocks in trunk are shot. I easily removed them. Any advice as to a supply source?
Thanks!!
Jerry Smith family
Old May 13, 2015 | 06:07 PM
Welcome to the forum Jerry,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
Old May 13, 2015 | 06:46 PM
andrew lowe's Avatar
Do your brake lights work? ... is there a click when you press the brake pedal?
If not, remove and repair/replace the switch.
Old May 17, 2015 | 05:36 PM
Thank you for the quick replies! I was away in Barbados for a few days.
The brake lights do NOT work when the key is OFF. They DO when the key / engine is ON. I do NOT hear any "click" when the pedal is pressed. Switch bad? Best place to acquire one? Thank You again!!
Jerry
aholbro1
Dec 29, 2024 06:46 PM
kevinl
Oct 31, 2019 06:15 PM
flyrr100
Mar 14, 2016 06:37 AM
Brewmonkey
Sep 20, 2015 01:43 AM
Brewmonkey
Sep 16, 2015 06:40 AM
