1999 xj8
Bought car used - the women explained the shifter problem as being hard to move into gear- she was a stout gal and continued to force the unit to get her to work. Now it wont move at all . I have disconnected it at the tranny and it is clearly seized. The brake lockout solenoid works properly too. I have ordered a used cable from Coventry West. My question is this - the tranny was in a default or limp mode when I drove it home- is there anything I should watch out for when I install new cable- ie should I just try to drive it or is there any thing to reset in tranny???
Hi topcoatserv
I started a new thread on the Driver Shifter Components:
https://www.jaguarforums.com/forum/x...rmation-70610/
Jim Lombardi
Jim Lombardi
Thanks for the help- just installed new shifter cable - reverse works great ! Forward gears seem to slip - is there any way to reset the tranny after it has gone into safe mode or is the unit junk?
Other than that, try a hard reset. Gearbox may also require some fluid. If it doesn't respond to any of this, then you can start considering the 'junk' assessment...
donald ebanks
Sep 30, 2015 07:08 PM
