2000 Jaguar XJ8 power seat
Old Oct 12, 2023 | 06:30 PM
Josh Nichol's Avatar
Default 2000 Jaguar XJ8 power seat
In my x308 the driver chair won’t tilt forward and it is tilted all the way back. Everything else works fine even tilting backwards, just not forwards. Is there any way I can force or forward or what would be the fix?
Old Oct 13, 2023 | 09:25 AM
Addicted2boost's Avatar
Possibilities:
Check fuses. If I had more time, I’d look at the wiring diagram and show you where the fuse(s) is located. I believe the fuse for the seats are in the heal (under the rear seat) board fusebox.
Broken wires behind the seat switch pack.
Seat module. You could remove the seat module from the passenger side and find a way to unplug the drivers side module and temporarily plug in the hood module just to see if the seat moves for you.
Old Oct 13, 2023 | 01:54 PM
RandyS's Avatar
Personally, from your description of the problem, it sounds as if the motors
are working and either the switches themselves or the connectors to the switches
are corroded and not giving good contact.
Old Oct 13, 2023 | 02:08 PM
motorcarman's Avatar
Please download and read all TSBs for your car.
Jaguar addressed issues for these car decades ago.
Here are 2 relevant TSBs.
File Type: pdf
File Type: pdf
papabil
Oct 26, 2020 08:17 PM
fxCycleworks1
Oct 19, 2017 05:09 AM
Hallmark
Jul 1, 2016 11:18 AM
FreedomFirst1776
Jul 22, 2015 10:24 PM
mweiss
Mar 11, 2011 07:28 AM
