2000 VDP - SC Premium Sound - AM/FM not working
Old Jul 23, 2014 | 10:49 PM
tlradcliffe's Avatar
Default 2000 VDP - SC Premium Sound - AM/FM not working
Hi Everyone,
I'm new to the forum and this is my first post! I've been to the dealer twice already and will be taking my jag back again next week for the same issues. In the meantime, I would be truly appreciative for any insight.
Problem - AM or FM static then no sound - OEM Premium sound system installed
Symptoms:
- AM/FM functional intermittently, usually until car warms up and then nothing but static
-AM/FM seeks and locks to local AM/FM radio stations, but no sound is played
- CD & Navigation sound systems are fully functional
Jag dealer wanted $1700 to replace the radio. After picking my self up off the floor because of sticker shock, I ordered a used radio from EBAY (exact same model) Husband installed new radio.
New Symptoms:
- NO AM or FM whatsoever
- CD and Navigation still work fine
- AM/FM seek and lock to local stations, but no sound. Not even static.
Any thoughts?
Many thanks,
Terri - Fairfax VA
2000 VDP-SC
Old Jul 24, 2014 | 03:00 AM
grandell's Avatar
Can't help with the stereo, sorry, but I would love to know where you found a used headunit, as I'm looking for one myself, but due to the nature of Ebay I'm having trouble finding one... it seems to limit my searches to only people the will send to New Zealand, which is almost nobody
Old Jul 24, 2014 | 08:46 AM
luc's Avatar
luc
Originally Posted by tlradcliffe
Hi Everyone,
Symptoms:
New Symptoms:
Any thoughts?
Many thanks,
Terri - Fairfax VA
2000 VDP-SC
Long shot but there is a switch on the bottom of the radio to change it from Prem to reg
The car sound system came in 2 configuration, base and premium but use the same head unit that need to be configured, through the switch, for the system you have, premium in your case
Old Jul 24, 2014 | 02:52 PM
grandell's Avatar
I thought that was only the case for XK's, not XJ's? Also, if that was the case, then there'd be no sound at all.
I had the radio out over the weekend, I really should have checked it more thoroughly... oops... unfortunately I was in a bit of a hurry and had other things to do.
Old Jul 25, 2014 | 08:28 AM
jimlombardi's Avatar
I just found another thread posting about am or fm no sound issue -
quote - one of the wires that lead to my power antennae was not connected correctly. I could not believe that could cause the sound to stop, but as soon as I reconnected the wire, it worked!
Here is the weblink to the thread (look at post #3):
https://www.jaguarforums.com/forum/x...diagram-74114/
Jim Lombardi
BrentGardner
29
Dec 16, 2024 12:13 AM
MJ'S Jag
Nov 10, 2022 08:14 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
nelsonht
Aug 30, 2015 06:01 AM
peterg19
Aug 28, 2015 08:42 AM
