2000 VPD Ignition Key removed Dash warning lights stay on,
Old Aug 15, 2013 | 07:06 AM
Bill McCarver's Avatar
Question 2000 VPD Ignition Key removed Dash warning lights stay on,
2000 VPD I have an intermitent problem that seems to be getting worse, I turn the igntion off car shuts down, but the dash warning lights stay on along with multiple messages on the dash screen, I suspect the ecm is remaining active. Where to Start?
Old Aug 15, 2013 | 01:19 PM
Probesport's Avatar
I would start with a potentially faulty ignition switch. When that situation happens, if you re-insert the key can you turn it on-off again to turn them off?
The second piece is possibly a door switch, perhaps it has not sensing the door being opened? Do your interior lights turn on/off properly?
MJ'S Jag
Nov 10, 2022 08:14 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
tberry6686
Sep 20, 2015 03:22 PM
Oliver9218
Sep 3, 2015 05:33 PM
Aranon
Sep 1, 2015 01:00 PM
