2000 XJ8 Cylinder 6 Misfire & a Broken Clock
Old Sep 7, 2016 | 08:51 AM
Brianna Renee's Avatar
Default 2000 XJ8 Cylinder 6 Misfire & a Broken Clock
I have a 00 XJ8. Restricted performance came on, so we started the cheap route and replaced the spark plugs. Kept happening. So we replaced coil 6 and 2 (we switched them to see if the same code would come on) which it did, so we can rule out a bad coil. What else could be causing this because trying to figure it out is expensive. Also, cloxk works but is really slow. Like it will lag behind.
Old Sep 7, 2016 | 09:56 AM
RJ237's Avatar
A weak battery can cause many problems, so have it load tested. It would be appreciated if you would list the actual codes.
Old Sep 7, 2016 | 10:46 PM
Don B's Avatar
Hi Brianna Renee,
+1 on having your battery load tested and having the fault code(s) scanned and posting the full codes here so you can receive the most accurate and thorough assistance. The codes will be in the form of P0306, etc.
Cheers,
Don
Uncle Fishbits
Oct 4, 2016 03:35 PM
Luckiecharm
Sep 8, 2016 11:44 AM
thedebs53
UK & Eire
Sep 8, 2016 01:43 AM
wcourt3010
Sep 2, 2016 12:40 PM
randyb
Sep 1, 2016 02:08 PM
