2000 xjr brakes?
Old Jul 15, 2008 | 04:25 PM
NorCalDiesel's Avatar
Default RE: 2000 xjr brakes?
ORIGINAL: river
I'm trying to purchase brakes for my 2000 xjr nd all these shops online give me 2 options or "different types" of pads. Do all 2000 xjr 4.0L supercharged Jags have the same interchangeable brake pad, both front and rear?
All brake pads that are spec'd for your XJR will fit. The difference you are seeing has to do with the composition of the pad material. I have used semi-metallics for the last 80k and have no issues and pretty good brake response with very minimal fade. They are relatively inexpensive, as the most expensive is not always the best. I change the fronts and watch the rears since they do not wear as fast.
What were the options you were given?
Also, more importantly is to make sure your calipers can slide laterally with no restriction. This will insure that the inboard and outboard pads will wear correctly and will not cause excessive heat from rubbing on one side. Heat is a rotor killer and if allowed to occur will cause hard spots on your rotor which will show up as a pulsating brake when coming to a stop
Old Jul 16, 2008 | 10:23 AM
ken@britishparts.com's Avatar
The "R" package can be on either the XJ8 or the XJR. Most do not have it.
Old Jul 16, 2008 | 10:24 AM
Pray that you don't. You are talking serious $$$$ for brakes!
Old Jul 16, 2008 | 10:28 PM
atom069's Avatar
I will always be pro-ceramic padding. My mechanic just popped this on mine
http://cgi.ebay.com/ebaymotors/ws/eB...89570&rd=1
the works. super inexpensive,breaks are SWEET now, very tight with such a smooth feel.My opinion.. semi-metallics are no dice. Nasty break dust and squeals.
Old Jul 16, 2008 | 11:02 PM
andnew's Avatar
Yup on the expensive for the "R" or "R1" packages.
Pads, front only, for my 03 XJR/R1 (Brembo)package is $500 from the dealer, and I'll be looking at rotors next time too. 64K miles.
They can be found cheaper, but I have no links at the moment with the new computer. I lost all my research.
Old Jul 16, 2008 | 11:06 PM
andnew's Avatar
Oh, and nobody makes ceramic replacements for the R package machines. At least as far as my research has taken me.
Old Jul 16, 2008 | 11:32 PM
andnew's Avatar
http://www.europartsdirect.comshows them at an attractive price. No affiliation, and not a customer.
Based on research only, this advice is worth every cent you paid for it.
Old Oct 25, 2012 | 01:35 PM
jagiam's Avatar
hi,can anyone tell me the correct part number for a 2000 xjr rear brake pads.thanks.
Old Oct 25, 2012 | 01:58 PM
Sean B's Avatar
go here by VIN...
Genuine Jaguar Parts and Jaguar Accessories for Classic Jaguars
Hope this helps
Forcedair1
Sep 8, 2025 01:57 PM
jdzubas
Oct 4, 2015 09:14 AM
KarimPA
Sep 12, 2015 08:15 AM
stype40
Sep 9, 2015 08:14 AM
obwoodie
Sep 3, 2015 07:45 PM
