2000 XJR OBD II Reader Advice
Old Jan 5, 2018 | 02:30 PM
Dr.Acula's Avatar
Unhappy 2000 XJR OBD II Reader Advice
Hey Fam,
So I've gone through a few posts on the OBD readers but I haven't had luck finding the proper one for my Jag. The one i was recommended on J Forums has negative reviews on amazon. I looked on Amazon for a second opinion and I'm getting mixed signals. Sad thing is I drove to my local Auto Zone store and asked to use their OBD reader and it worked like a charm. I've purchased 2 Euro readers on amazon and none of them work. Does any one have any suggestions ?
These are the readers Amazon recommends:
iCarsoft LR V1.0 ($109.00)
iCarsoft i930 ($99.00)
NT510 ($180.00)
Old Jan 5, 2018 | 03:17 PM
Highhorse's Avatar
Elm327 Bluetooth
Old Jan 5, 2018 | 03:38 PM
Dr.Acula's Avatar
Penelope, Recommended that model i believe but i got mixed reviews online . Ill buy it today, its only $15 ... compared to the others! Thank you Highhorse! Ill let you know how it works.
Old Jan 5, 2018 | 04:34 PM
Jhartz's Avatar
I use an Actron 9575. Easy to set up for the 2001 Jag, but worked out of the box on my wife's Maxima and on the 2-13 Range Rover Sport. Bought an Actron for my son: his is bigger and does more stuff than the 9575 (body and transmission codes). Pretty cheap and easy. But guys using the ELM with Android phones (me, iPhone) seem to have excellent results with more data.
Old Jan 5, 2018 | 04:54 PM
Lady Penelope's Avatar
If you use the USB version of ELM327 with laptop you may have more options on the data graphs vs . smartphone
King Charles's Avatar
I run Torque Pro app w/ the $12 Panlong bluetooth scanner from Amazon, it's been flawless 2 years in.
Amazon Amazon
Old Jan 5, 2018 | 05:30 PM
Highhorse's Avatar
+1 KC, I use the Torque Pro with my Elm. As you can see Christopher, from the responses, there are a few options available.
Old Jan 5, 2018 | 05:31 PM
Dr.Acula's Avatar
Thank you ! I think ill buy 2 different units and try both at the same time. As of now i have no lights on but I'm curious to know why a yellow light goes off when i hit hard bumps at an average speed of 25-30. Ill make a log on the reader and reliability here.
Old Jan 5, 2018 | 05:32 PM
Dr.Acula's Avatar
Perhaps this is a silly question but.. Does it make a big difference from a 2000 to a 2001 model XJ? I had read some sensors wont work even tho its 1 year difference?
Old Jan 5, 2018 | 05:34 PM
Highhorse's Avatar
I know nothing of these not working on other years, OBDII is OBDII. I have used it on my 2012 Dodge Caravan also.
Old Jan 5, 2018 | 06:11 PM
ericjansen's Avatar
Yes, you are right, some readings do not work on the 2001 model, but I think it is limited to a flaw in the Torque App, not sure.
richardgrantham26
Dec 15, 2013 12:22 PM
jaguar38s
Aug 24, 2011 01:50 AM
Dracomeister
XJ40 ( XJ81 )
Aug 5, 2011 04:15 PM
ptl
Mar 23, 2009 03:43 AM
