2001 Jaguar VDP
Old Apr 20, 2011 | 12:40 AM
Cfraijo's Avatar
Default 2001 Jaguar VDP
Hi,
I believe the VDP is almost identical mechanically to the XJ8 except for some extra chrome & trim, etc.
A month ago I replaced an alternator that was shorted to ground. After replacement, the Radio and Power seats would not work(in manual mode).
I searched this forum before becoming a member and a post directed me to the fuse location for the radio. The fuse was blown and now radio is in operation. Info was very precise...Awesome!
Now am trying to locate root cause to the Power Seat operation problem. Both front seats have the same issue: they will move when I depress the memory button, but won't operate with the manual switches on the side of seats. The motors operating the seats must be ok but don't know why they won't operate when I try to adjust them manually.
Thanks for any suggestions...
Old Apr 20, 2011 | 01:15 AM
QuadManiac's Avatar
1st, welcome to the forum!
Yes, the VDP and XJ8 mechanically and electrically identical, save a couple of additional minor features, if I recall.
If it will help, and if you're comfortable reading the technical content, here's the wiring diagram for your year... It will tell you how the seat controls are interconnected, starting with figure 12.1.
http://www.captainjaguarscathouse.co...ec%20Guide.pdf
From the wiring diagram, the one thing that stands out to me is that the manual seat switches all receive power from a pair of fuses - Left seat is in LH Heelboard Fuse Box, fuse #8, 5A. Right seat is in RH Heelboard Fuse Box, fuse#5, 5A. I'd check these first. The memory function is powered elsewhere, so it would still work even if these fuses were blown.
Old Apr 20, 2011 | 01:19 AM
Cfraijo's Avatar
Quadmaniac,
thanks...I'll check it out. Love this forum!
Old Apr 20, 2011 | 01:35 AM
QuadManiac's Avatar
It is one of the best I've ever found.
kp98xj8
Sep 26, 2015 10:44 AM
celticpiping
Sep 18, 2015 06:17 PM
rudelover2
Sep 11, 2015 08:53 PM
plums
General Tech Help
Sep 1, 2015 06:34 AM
dpappyp
Aug 27, 2015 06:31 AM
