2001 Jaguar XJ8 HELP
Old Oct 15, 2010 | 07:04 AM
doglegleft2k3's Avatar
Default 2001 Jaguar XJ8 HELP
Car runs great with 60,000 miles on it, however, there is a continuous tapping noise coming from the motor?? I have been told that it may be the original tentioners? Is this common?
Old Oct 15, 2010 | 12:39 PM
From what I read around here, yes it is. Check out the XJ8 section FAQ I am sure that you will find more info.
Old Oct 16, 2010 | 08:33 AM
jimlombardi's Avatar
Default Have tensioners been replaced on your Jaguar
Do you have the repair history? Have the original tensioners been replaced by the updated 3rd generation tensioners? If not, then I would recommend having yourself or a mechanic pull off the valve covers on both sides of the engine and check to see if the plastic upper secondary tensioners have failed or have cracked (about to fail). Even if they are ok now. If they have not been replaced 3rd generation ones, I would have them replaced now.
Use these 2 websites links to views the information on tensioners problem:
http://www.jagservice.net/jaguar_v8_...tensioners.htm
http://www.jcna.com/library/tech/tech0028.html
Also do a forum search using "tensioners" limit it to the forums of Jaguar sections XJ8 & XJR; XK8 &XKR. That should give enough information on these tensioner problems (posts give others' experiences, DIY, Costs, etc).
Hope this helps.
celticpiping
Sep 18, 2015 06:17 PM
MarathonJohn
Sep 3, 2015 07:59 PM
Will P
Aug 27, 2015 06:52 PM
dpappyp
Aug 27, 2015 06:31 AM
souldoubt
Aug 25, 2015 08:15 PM
