2001 Jaguar XJ8 oil?
Old Jul 16, 2018 | 04:35 PM
RyanTheRhino's Avatar
Default 2001 Jaguar XJ8 oil?
What oil and how much should I use on my 2001 Jaguar XJ8 Base Model 4L V8?
Old Jul 16, 2018 | 04:42 PM
Robman25's Avatar
Probably as much as Jaguar suggest along with the correct grade for your location?
Probably 0W30 or 5w40 or as Castrol suggest 0w40 :- and up to the top of the hatch mark on the dip stick.
://applications.castrol.com/oilselector/en_gb/c/recommendation?vehicleType=cars&manufacturer=jagua r&model=xj-x308-x350-x358-(1997-2009)&modelType=xjr-(1997-2001)
Old Jul 16, 2018 | 06:39 PM
Iconoclast's Avatar
My 2000 XJ8 takes exactly 8 quarts. I use Mobil1 5W-30. I'm in the USA desert southwest so hot summers, virtually no winters.
Do you have the Vehicle Care Handbook?
Here is the one for MY2000.
Old Jul 16, 2018 | 10:22 PM
Carnival Kid's Avatar
I find that the capacity of my 2001 VDP is just over 7 quarts, I fill with 7 quarts and then check and add carefully until the dipstick shows full.
I use Castrol GTX 10-40, I have read that the slightly higher viscosity is advantageous regarding pressure lubrication of the timing chain tensioners.
Mjr 1975
Jul 3, 2024 10:20 AM
n17gary
Jun 26, 2018 04:52 PM
Duck991
Jun 10, 2018 05:56 PM
jaguarsilverstone
Jun 4, 2015 07:09 PM
