2001 XJ8
Old Mar 3, 2019 | 09:26 PM
Marques's Avatar
Question 2001 XJ8
Just before I took a little trip today, I checked out my communication signals to see if all was working.
I found out that my right front passenger signal light was not working but all other signals worked. I replaced my light bulb but it still does not work? I would think if it was a fuse, other signals would not work. Could this be a faulty casing around the bulb?
Anybody out there have his issue or know a fix?
Old Mar 4, 2019 | 02:10 AM
Welcome to the forum Marques,
I've moved your question from General Tech Help to X308 forum. This is the place to post technical questions about your model.
Old Mar 4, 2019 | 08:14 AM
Marques's Avatar
Thank you Graham! Hopefully I will be able to navigate around here soon.
Old Mar 6, 2019 | 08:41 AM
Samilcar's Avatar
When my right front turn signal wasn't working, I traced it to the wire harness connector being packed full of silt. The previous owner(s) had lost the front undertray shield, exposing this connector to road debris.
Old Mar 6, 2019 | 09:22 AM
Marques's Avatar
I thought I would have to trace it to see if there was a problem along the line. I have no garage, so I will have to wait until the weather gets better up here. Thankfully it is the front right passenger turn signal and not the left side.
Thank you for the reply to my issue!
Scotchgitt
May 24, 2017 01:22 PM
Piersman
Nov 9, 2016 01:40 PM
toronadomike
Dec 11, 2013 01:57 AM
Apr 13, 2007 01:14 AM
