2001 xj8 4.0 Timing Chain Replacement
Old Feb 15, 2022 | 01:06 PM
  #41
redeye1962's Avatar
update from the shop. the next step is to retard the vvt a bit. If I recall that is where I had some uncertainty if I did those correctly when I replaced the timing chain..................dang man. this is crazy. but just in case I am going to start looking for an ecu. I got the vcat info. the shop was not sure they could program a used ecu so the only option I have is new. will begin the search. As always I appreciate the support here.
Old Feb 16, 2022 | 09:23 AM
  #42
motorcarman's Avatar
The ECM DOES NOT NEED TO BE 'PROGRAMMED', only needs IMMOBILIZATION SETUP!!!!!!!!!!
I did 'PROGRAM' ECMs 'back-in-the-day' when Jaguar issued a SERVICE ACTION or TSB to correct some software issue.
As long as the ECM VCATS suffix and part numbers match, the ECM can be installed and THEN the immo-setup is performed!!
Engine starts, you are on your way!!
EXAMPLE of Jaguar issued ECM 'programming' for software change TSB 303-35 amended.
Old Feb 22, 2022 | 04:52 PM
  #43
redeye1962's Avatar
Thanks for the info. would any "used" ecu with warranty work? hard to find a new one.
Old Feb 23, 2022 | 08:27 AM
  #44
Old Feb 23, 2022 | 09:11 AM
  #45
redeye1962's Avatar
Appreciate the information. I am still waiting to hear back from the shop about retarding the VVT. I hope that fixes the issue but it does smell like the ecu.
Old Mar 8, 2022 | 09:45 PM
  #46
redeye1962's Avatar
OK so I am asking around to see if anyone knows anyone who can take a look at this thing for me. It has been at this shop for almost a year and is still not fixed. I am in the DFW area, the car drives fine but get the VVT sensor errors. It does make sense the VVT may need to be retarded and could fix it but really want someone who can take a look at it to determine what the next move should be. I have called a few places but they are too busy. If anyone wants to take a stab at it let me know.
Old Mar 30, 2022 | 02:18 PM
  #47
redeye1962's Avatar
Does anyone know someone in the DFW area who may be able to take a look at this jag for me?
Jaguar XK8er
Feb 11, 2023 08:06 PM
jbalbo
Jan 13, 2022 04:02 PM
Strokeman
22
Sep 3, 2015 12:24 PM
doglegleft2k3
Dec 10, 2010 07:02 PM
cometgold
Mar 31, 2009 11:09 PM
