2001 XJR fault code please help
Old Mar 15, 2012 | 04:09 AM
steveaston 2001 xjr's Avatar
Default 2001 XJR fault code please help
Hi I have just downloaded the following codes from my car I think it is the Lambda sensors that are at fault but if you can help that would be great. The car is running badly at tickover (misfiring) and lacks power ( it runs out of steam at about 135 mph were it should do 155mph)
P0300
P0301
P0302
P0303
P0304
P1316
P0420
P0430
P1000
P1113
P1647
If I am right and it is a Lambda sensor which one of the four is it.
Thanks for your help.
Old Mar 15, 2012 | 06:23 AM
Passed this a couple of times on my way down to XK8 section. Assuming your XJR will be the same DTC code set as my last 2001 XK8, here's the list:
P0300 = random misfire detected
P0301 = misfire on A1
P0302 = misfire on A2
P0303 = misfire on A3
P0304 = misfire on A4
P1316 = misfire excess emission
P0420 = catalyst efficiency below threshold on A bank
P0430 = catalyst efficiency below threshold on B bank
P1000 = drive cycle not completed since last code clear
P1113 = IATS 2 sensor low voltage
P1647 = ECM HO2S control malfunction B Bank upstream
Good luck.
Old Mar 15, 2012 | 06:32 AM
test point's Avatar
Another thing that could cause a single bank issue is if the exhaust cam chain had skipped a tooth due to a failing tensioner. That would screw up the O2 sensor readings and cause the MAFS/ECM to over compensate causing the B bank issue.
Old Mar 15, 2012 | 06:53 AM
Good point.
Any doubts on tensioners and you need to be more worried about moving the next 135 feet than you do about investigating performance beyond 135 mph.
Old Mar 15, 2012 | 04:17 PM
Thanks for that I know it is not the tensioners as it is a late model engine with the uprated tensioners, so any other ideas would be welcome, so I would be open to any other suggestions.
toronadomike
Jan 22, 2026 10:13 PM
cissdm
May 3, 2016 06:02 AM
skadmiri1
Sep 9, 2015 11:27 AM
TexasCat
Sep 8, 2015 04:36 AM
