2001 XJR valve cover gaskets
Old Oct 22, 2010 | 11:29 PM
Mafioso68's Avatar
Unhappy 2001 XJR valve cover gaskets
The left side started leaking a very small leak a couple of days ago, I already have the parts, should I attempt to do it myslef?
I do have some mechanical knowledge and have worked on various cars that I've owned in the past. Is it simple, or should I just pay someone to do it? Does anyone know what the torque specs are?
Old Oct 23, 2010 | 03:24 AM
test point's Avatar
Replacing the gaskets is a very easy task. Two issues to deal with; you have to remove the oil dip stick tube and mine was a little difficult to get back in and moving the coolant reservoir is required. Don't drain it, just move it out of the way to get to the lower corner bolt.
You may find the spark plug holes full of oil. Cover each of them with a rag and blow the oil out with compressed air or suck it out with a turkey baster with a small tube extension.
Careful of the electrical connections on the coil packs. Old plastic can be brittle.
Don't know torque specs but it is so low that I don't have an inch/lb torque wench. Quarter inch ratchet, two fingers and a thumb. Tightening them too much will only crack the plastic, not seal better.
Old Oct 23, 2010 | 06:54 AM
TN8Shooter's Avatar
I would also recommend changing the spark plug seals to prevent oil from filling the holes again. I also learned the hard way to use a premium gasket set (OEM).
Good Luck
Old Oct 23, 2010 | 10:33 AM
GW2059's Avatar
Cam cover bolts 9 to 11 N/m (Start with the two in the middle and then the bolt middle bottom then in a circular/opposites pattern with the last bolt being front top)
Remember to use RTV sealant (3mm dia' & 12 mm long) at the two flats on the head (joint between timing cover and the cylinder heasd), cam cover on immediately.
Coil bolts 4 to 6N/mm
Coil cover bolts 4 to 6N/mm
Regards
Gary
Old Oct 23, 2010 | 11:26 AM
Dan R's Avatar
Use gasket remover to clean up the gasket mating surfaces.
Do not take out the dipstick as per the manual. Remove the dipstick brace from the cam cover bolt and rotate the dipstick to one side. May require a bit of careful pulling and tugging.
Good time to change plugs and secondary tensioners if plastic bodied.
Old Oct 23, 2010 | 12:58 PM
Mafioso68's Avatar
Thank you all so much, the tensioners have already been replaced with the metal bodied ones, and the plugs were also recently replaced. I am replacing the spark plug seals at the same time.
Old Oct 24, 2010 | 05:25 PM
Mafioso68's Avatar
Old Oct 28, 2010 | 06:37 PM
Mafioso68's Avatar
Default yaaaaay
I did it, I did it, boy it feels so good to not leak
Old Oct 28, 2010 | 06:39 PM
benebob's Avatar
ud
How long did it take ya? Both side?
Old Oct 28, 2010 | 07:49 PM
test point's Avatar
Congratulations!
Feels good to love the car doesn't it.
Old Oct 29, 2010 | 10:08 AM
Mafioso68's Avatar
Both sides took about four hours, mind you this was the very first time for me to work on the engine and I was exploring my way through it all. It is a simple straightforward job though once you figure out what you're doing and what needs to be taken off and what doesn't.
Oh yeah, I'm loving the car specially now after installing the cold air intake and feeling the noticeable power gain. http://www.minagallery.com/jagxp/Jag...e%20intake.htm
Old Oct 29, 2010 | 11:26 AM
fitnessrx's Avatar
I have the same problem. What parts did you buy?
Old Oct 29, 2010 | 08:14 PM
Mafioso68's Avatar
I ordered two gaskets and four spark plug seals from autopartsway
http://www.autopartsway.ca/autoparts2/index.cfm?fetch=part~ID=2001~Jaguar~XJR 4.0 V8 Super-Chrg~240452
http://www.autopartsway.ca/autoparts2/index.cfm?fetch=part~ID=2001~Jaguar~XJR 4.0 V8 Super-Chrg~240450
Old Oct 30, 2010 | 06:07 AM
fitnessrx's Avatar
None of em worked. Which one on this site is it?
http://www.britishparts.co.uk/.sc/ms...rch=gasket+xjr
Old Oct 30, 2010 | 11:05 AM
Mafioso68's Avatar
http://www.britishparts.co.uk/.sc/ms...COVER%20GASKET
or
As for the seals,
two of these http://www.britishparts.co.uk/.sc/ms...%20BOSS%20SEAL
Old Oct 30, 2010 | 02:06 PM
fitnessrx's Avatar
Thanks alot! I really appreciate it
Old Jun 12, 2011 | 09:05 PM
Jaguar1's Avatar
Default cam bearing caps
Does any body knows the torque for the cam bearing caps?
Thanks for the help....
Old Jun 14, 2011 | 01:38 PM
Mafioso68's Avatar
I apologize, but I do not.
Old Jun 14, 2011 | 01:52 PM
Dan R's Avatar
9-10 Nm. Remember to unfasten and refasten gradually and equally on all bolts. "loosen (tighten) them evenly, in stages" from the manual.
Old Jun 15, 2011 | 09:06 PM
Jaguar1's Avatar
Default cam cap torque.
Dan thank you so much you help me alot, thank you! Jorge Hdz.
