2002 Sport, p1121
Old Jun 12, 2018 | 04:17 PM
Z07Brandon's Avatar
Default 2002 Sport, p1121
Went to my job, came back out about 10 minutes later. Upon startup, the car was running rough. Threw the failsafe message. I always connect my obd2 to monitor temps, so right there I scanned codes. Which gave me the p1121. Turned the car off for like a minute. Started it back up, and got me home with no problem, no failsafe. Car hasn't done it to me in almost exactly a year ago, then today. I'm not even complaining.
119k miles, if that matters.
What all do I need to check?
Brandon
Old Jun 12, 2018 | 04:43 PM
avern1's Avatar
The code indicates a throttle position sensor failure. I would remove clean and polish the throttle body connections then clear the code and see if it returns,
There is a TSB about replacing the pins in the connector for the throttle position sensor plugs.
Take a browse thru the "How to" section for th x308 and see if you can find it. PM me I think I have it stored somewhere.
Old Jun 12, 2018 | 06:03 PM
Sean B's Avatar
The 02 cars have the updated gold pin connectors, more likely dirty or worn tracks within the sensor, they do wear out and cause plenty of failsafe issues.
ASI rebuild them fortunately
Old Jun 12, 2018 | 07:41 PM
Z07Brandon's Avatar
Good stuff guys! Before unplugging the throttle body connections, do I disconnect the negative side on the battery? Nice to know 02 cars have the updated pins, thanks Sean! Who is ASI?
Old Jun 12, 2018 | 09:38 PM
King Charles's Avatar
Originally Posted by Z07Brandon
Who is ASI?
https://www.autoecu.com/
Automotive Scientific Inc. (ASI)
5168 Hwy 11W Rogersville Tn. 37857
Hours - 9am to 5:30pm EST
Toll Free - U.S.A & Canada: 1-866-983-6688
Old Jun 13, 2018 | 10:45 AM
Z07Brandon's Avatar
Can we buy separate throttle position sensors? What about pedal position sensors? Where is the pedal position sensor located? Haven't diagnosed anything. But I am about to clean the connections. I assume to disconnect the negative cable before doing so?
If I end up needing a TB rebuild, is there a way I can be sure of that? When they rebuild it, do they give us new a throttle position sensor and pedal position sensor?
Old Jun 13, 2018 | 01:08 PM
Z07Brandon's Avatar
Cleaned the throttle body connections, only saw 3. Yes, the TPS does have gold pins. Is it me, or the TB looks to have been replaced or rebuilt? I say that because of the white markings. And it's pretty clean.
On to some pics.
bigevent
Jul 8, 2013 10:48 PM
korvetkeith
Jul 5, 2013 03:05 PM
J.Bo
Jun 7, 2013 08:08 PM
bretts1174
Oct 23, 2012 11:37 PM
jimlombardi
Sep 23, 2011 01:35 PM
