2002 VDP Timing Chain Mod Prep
Old May 3, 2012 | 06:46 AM
mechelement's Avatar
Default 2002 VDP Timing Chain Mod Prep
Today I pick up our 2002 VDP w/ 77k on it. Full service records since the build date June 2002, one owner, timing chains or tensioners are not within service documentation...
I must've read 100+ threads about the timing chain tensioners, chain guides, early x308 all plastic, then the plastic tensioners w/ springs and finally the all metal ones. I've noticed several discrepancies during my readings, especially from other sites which actually sell the all-metal (3rd gen??) timing chain kits...
Were the chains themselves improved after 2001 to a heavier chain?
The actual cutoff for plastic chain tensioners is end of August 2002, correct?
Since mine is a June 2002 build, I assume I have the heavier chain, but plastic tensioners and guides, which should be replaced with the superior metal system. Is this correct?
I've read some Lincoln 3.9L engine parts fit the Jag 4.0L engine, such as gaskets and the upper tensioners. I've seen 1998-2001 Jaguar when mentioning Lincoln parts. Do the Lincoln parts still fit the 2002? What about the guides and chains themselves? Are the guides and chains for the Lincoln 3.9L the pre 2001 design, thus smaller?
To keep it brief, I am trying to obtain all parts necessary to perform the entire timing chain system modification in the most cost effective manner without sacrificing quality. I've sourced kits sold in England and they seem to be hundreds less than those sold in the US, but I do not know the cost of freight. Is it more cost effective to piecemeal this kit together by using gaskets and upper tensioners from the Lincoln and the chains and guides from Jaguar? I feel like I'm making assumptions based on reading hundreds of posts and websites, but would like to hash it out before making the plunge.
Old May 3, 2012 | 08:39 AM
Boomer from Boston's Avatar
I thought Jaguar went to metal tensioners in August 2001. You might be OK.
Old May 3, 2012 | 09:32 AM
Aside from me eating crow in regard to my first thread in this forum, that would be outstanding.
Old May 4, 2012 | 08:29 AM
My mistake, build date is June 2001.
Cutoff was August 2001?
Old May 4, 2012 | 09:12 AM
Well, in that case, you probably DO need to worry about your secondary tensioners!
Old May 4, 2012 | 10:39 AM
I don't get any noise at startup... Yet. So back to my original post questions. Any guru answers are greatly appreciated.
way2far
Aug 31, 2022 09:26 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
meanman
Aug 7, 2016 10:15 PM
Raul Lara
Sep 14, 2015 07:31 PM
Raul Lara
Sep 2, 2015 05:23 PM
