2002 xj8
Old Oct 23, 2014 | 11:48 AM
TsSmith's Avatar
Question 2002 xj8
I just purchased a 2002 XJ8 and it has a rattle in the engine when it idles. It goes away after a while. Lifter? The car is in mint cond. and only has 88,000 miles.
Old Oct 23, 2014 | 02:11 PM
bdboyle's Avatar
I'm thinking it is probably the secondary cam chain tensioner(s). Rattles in the engine are not normal. Mint condition in appearance has nothing to do with interior condition of an internal combustion engine. Get it checked out.
Again, rattles in an engine are not normal.
Old Oct 23, 2014 | 03:46 PM
I've moved your post to the XJ (X308) section for better visibility and where members with the same model can offer assistance
When you have a moment, please stop by the New Member section and post an intro - in return, you will receive a warm welcome and some useful tips to navigating the forum
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
enjoy
Old Oct 23, 2014 | 04:38 PM
Jhartz's Avatar
Howzabout some more information than just a rattle: where, on start up, or while idling, when cruising. If it is at start up, it is secondary tensioners (90% positive) and the timing is about to jump a gear and ruin your engine (80% positive); at idle, guessing water pump (if original, a weak link, will ruin your engine - 70% positively going to happen), if at cruising speed, engine may already be toast (~50%).
Old Oct 23, 2014 | 07:31 PM
avt007's Avatar
Do a search for VVT and look for videos. I posted one myself. They often rattle when cold.
Post more info and you will get good advice.
donald ebanks
Sep 30, 2015 07:08 PM
Amberlinder541
Sep 30, 2015 07:07 PM
JAMES1944
Sep 29, 2015 11:58 AM
UKnFor-dluv-expat
Sep 26, 2015 08:40 PM
jessejamestw23
Sep 26, 2015 03:57 PM
